will intexas
New User
the three point would not raise found some on must have taken the block apart on the system and lost the ball bearing on the releif side found an old bearing that had rouflythe size i needed put it back in works fine now will lift post hole digger then replaced the valve cover gasket and oil pan gasket installed a new distributor set timing good the put new universal joints in steering shaftgasket in the sediment bowl the old girl runs and works great the only thing to do is rewire it and hook up the lights and new light switche after that hook up blade then go work
