It's an IH distributor on my Case SC. I worked all day on it and can't seem to get it to fire. I have power at the points. I put a new set of points and condenser in it. I checked the coil wire distributor post to make sure it wasn't grounded. I switched out the coil for one that I new was working. The points and condenser were in the original package on a shelf in my garage for about 15 years. Could it be the condenser? The distributor wasn't working and I did some work on it. The distributor shaft is still slightly bent and the point gap varies a little as it goes around, but the points are breaking and I have power to the points. Any suggestions? I am out of ideas.
