Older case 310b. We have been having starting problems. It ran for 100 ft and then died and would start and run for a few mins. Then died and wouldn't start at all except on starting fluid and then dies after that's gone. Checked and verified its getting fuel to carb. Replaced old carb. New spark plugs, wires, distributer, battery. ONLY STARTS AND RUNS UNTIL Starting fluid is gone when sprayed into carb. We had it apart for awhile and it rained. Oil had water in it, flushed oil. Pulled exhaust/intake manifold because it looks bad and gasket could be leaking. Seems that there isn't enough vacuum to suck in the fuel? How do you tell if the valves are burnt up? HELP!! We are pretty good with equipment repair but this seems to be a engine issues and we are stumped.
