188D Head Gaskets
John Saeli
What a nitemare. 630 book lists a Head Gasket A35196, goes to a 1349115C1. No fire rings. Small flange 188. Then, a 430-530 book prior to 8262800 lists before & after engine # 2119235, but both engines use an A36877 - 1349116C1, w/ fire rings. Then, the late 430-530 says engines before & after 2627377, & lists the A36877 before & A38640 after 2656844, w/ fire rings. I only know of 2 different sleeve flange sizes. I are cornfuzed.
(quoted from post at 14:50:15 03/14/14) What a nitemare. 630 book lists a Head Gasket A35196, goes to a 1349115C1. No fire rings. Small flange 188. Then, a 430-530 book prior to 8262800 lists before & after engine # 2119235, but both engines use an A36877 - 1349116C1, w/ fire rings. Then, the late 430-530 says engines before & after 2627377, & lists the A36877 before & A38640 after 2656844, w/ fire rings. I only know of 2 different sleeve flange sizes. I are cornfuzed.
Hello...I am running into same problem...Did you come to some solution?
H
