JT's RandR
Ok guys we have a 2590 case at work. Came in complaining of noise like grindingcoming from tranny area. We split tractor and found planetary carrier was wore around the bearing supporting it on tranny shaft. Replaced it and while there we took apart the clutch packs to check plates because c4 was bad didn"t find any others bad. Put it all back together and drove today and power shift slips in 1 and 3. Determined according to I T manual that c2 clutch pack not working. Checked pressure and had full pressure at check port. Whys it slipping and where do we look next? We didn"t rebuild pistons on clutch packs didn"t take them apart either so don"t think the seals there would be leaking. Any help greatly appreciated thanks Justin.
