case 530 power steering pic
Nick, I just got done replacing the seal, wiper and rings on my 530. I can't see your photo so I do not know if you are working with a wide front end or a row cropper, mine is a wide front. My solution was to remove the wire that locks the adjusting plug in place then I took an old 15/16" socket and a grinder and made a socket that would fit into and unthread the adjusting plug. The cylinder came out with no problem. A previous owner of the tractor had welded the adjusting plug on the other cylinder so I rebuilt it from the other end. That was a bit tricky and I had to undo the nut with the tires in one possition then take the cylinder housing while moving the tire to allow for more space. Be careful when putting everything back together (DONT HAMMER).
It's a wide dront the picture is on another top here named nick167 has a question it would not upload then I email chuck the pic and he posted it for me
