730 eagle hitch
You could say I'm a newby around these Case tractors. Got a 730 last fall. Question is, why does my eagle hitch raise up into the seat until you loose all of your suspension. Wrong cylinder? Wrong seat? I don't know but doesn't seem right.
Yes I have original 830EH the lift arms hits the seat also, guess I could tighten the spring a little more. Derek
I bet the problem is the fact that the rubber torsion sppring is getting weaker as time passes allowing the seat to go lower and lower. I aquired an 830 EH and the seat was sitting at the extreme bottom.
