how to jack up front end on case 730 narrow front end
Durk
New User
Need to grease bearings on a case 730 narrow front end. Whats the easiest and safest way to get tires off ground? Front end is like 2-3 feet off ground. thanks for any replys
Just run one wheel up on a block, and do your repairs to the other, and then run the repaired wheel on the block and do the other. No jacks needed.
Loren
duh ,,do one wheel at a time by rolling up on a 2 x 4 ,, this will be the only time you will be glad Case did not buy into the ROLL o MATIC idea
