Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Case dc tractor
jdetig1
03-06-2014 04:33:53
50.44.45.214
I'm going to buy a dc case from my uncle that's been in the family forever. I've only worked on IH tractors so this will be a little different. What weight of oil do you use for the engine, hydraulics, and rear end? For the wet clutch if I just fill the crankcase will the oil get into the clutch or do I have to fill it separate? Anything else I should check besides the normal things?
[Reply]   [No Email]
Ron Sa
03-06-2014 09:12:43
75.107.150.95
 Re: Case dc tractor in reply to jdetig1, 03-06-2014 04:33:53
What year is the DC? I would enjoy its story and a picture or two.
If liquid was kept in the radiator most of its life, you will probably not encounter my biggest problem restoring DCs---getting the rust flakes and rust paste out of the radiator cores and the engine block. A radiator cleaner and flush will not deal with flakes or clean cores already plugged.
I have resorted to painstakingly rodding out cores from the bottom. To keep more flakes from being pumped onto the top of the core, I have built rust traps as shown. They work. I see one pic is duplicated. The pipe plug has a STRONG magnet inserted into it. The elbow is machined as needed to weld in a pipe coupling and then a large opening is machined into the wall of the coupling entering thru the lower flange of the elbow.
I remove the plug ever once in a while and the trap is full of rust fines and flakes. The top of the core stays relative free of flakes.
[Reply]  [No Email]
SDLars
03-06-2014 06:30:26
68.69.68.86
I'd add that an owner's manual would be helpful. They are fairly plentiful on ebay and such.
[Reply]  [No Email]
j hikemper
03-06-2014 06:14:46
50.102.76.173
when I was a kid dad and his uncles ALWAYS beat into our head that a hardworking DC MUST have a minuimum of 40 wt oil,, and to use 50 wt.in hot summer .... probably not the thing to do anymore, with modern oils we have now
[Reply]  [No Email]
Glenn F.
03-06-2014 04:53:22
166.181.3.234
Resisting the urge for any wise cracks about red tactors going up for sale soon. Just funnin! You will love that DC.
We have three DC tractors, a '51,'52, and'54. Dad bought the '51 new. Tough tractors.
OIL
Engine---30 for summer. Or else just s good multi-grade.
Transmission---straight 90 gear lube (about 11 gallons)
Hydraulic Pump---We run 30 non-detergent. Don't run it low.
Wet Clutch is fed with engine oil. Be sure to remove plug in pan and plug near clutch when changing oil.
We love our DCs. Only wish CASE woulda put a 5-speed in them. Low gear can be a little fast on the chopper.
Glenn F.
[Reply]  [No Email]
casecollectorsc
03-06-2014 04:50:47
64.33.231.221
Drain the crankcase and clutch housing and refill with a good 30 weight oil. Rear end and trans. take 80-90. Hyd. system uses Hy-tran. Good old tractor's.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
