2670 transmission pressure gauge
1968 403
Hi everyone. The indicator on the tranny pressure gauge runs in the lower part of the green it has since we bought the tractor. Tractor shifts and pulls fine. We use hy-tran and Case filters. Could the low pressure reading be a sign of possible powershift trouble to come? TIA Keith
I have had my 2470 for 20+ years and it has always run on the bottom of the green also. Shifts and pulls good. I shift to the speed I want and then put the implement in the ground, thinking it saves on the power shift. I have been told the hyd. pumps are discontinued.
casecollector we have had the hydraulic pump rebuilt on our 2590. Theres 2 places around here that rebuils them. I was somewhat concerned about the low transmission pressure reading. Thanks for the reply
I have two Case 1370, and thats almost the same transmission. The pressure gauge is maybe not that accuracy. If you want to know for sure, I think you should connect a external more accuracy pressure gauge.
My two tractors does not show the exaxtly same pressure, but I think that depands on the accuracy in the pressure gauge.
But if it shows different pressures depending on the gear, I guess something is wrong.
