Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case 530
j hikemper
02-23-2014 19:01:21
the syptoms you have ,,../indicate the rock shaft piston seal has failed ,, remove the seat and tranny cover ,, My advice is to take it to a hydro shop ,, Because that seal is difficult to reinstall in the barrel without damaging it ,,, Search Archives here for more info ,,,...
Luke higgason
02-24-2014 08:42:50
 Re: Case 530 in reply to j hikemper, 02-23-2014 19:01:21
Can I remove the rockshaft piston assembly and take it to a shop or do you recommend I take the whole tractor to a shop?also my tag for my serial number is gone off the dash. Is there any other way to find out the s/n.
Joe Young
02-24-2014 13:04:43
 Re: Case 530 in reply to Luke higgason, 02-24-2014 08:42:50
Luke
It's really not that hard to remove the assembly, or replace the seals for that matter.
Once the serial number plate is lost, there is no way to find the exact serial number. If you can post a few pictures, we can get you within a serial number range....usually a couple of years in length...
j hikemper
02-24-2014 19:44:46
 Re: Case 530 in reply to Joe Young, 02-24-2014 13:04:43
true ,, except after the 3rd time in as many yers of failure makin this repair ,, I decided I was not doin something rite and took it to the experts ,,.
Joe Young
02-24-2014 20:45:43
 Re: Case 530 in reply to j hikemper, 02-24-2014 19:44:46
Jim, I meant no disrespect. It sounds like your luck with the rocker arm piston is consistent with my success rate with the seals on the brake shafts..... I've actually had very good luck with several rocker arm pistons, but have yet to get one of the brake seals installed properly the first time...
j hikemper
02-24-2014 21:05:57
 Re: Case 530 in reply to Joe Young, 02-24-2014 20:45:43
none taken , joe ,,. round here though ,sometimes,, my repairs have to be done only twice to make it a lasting repair ,, lol
Luke higgason
02-24-2014 13:42:09
Is there any pictures you need in particular. I wasn't sure if I needed it to find the rights parts. I am also having a govenor issue with it so I was gonna replace the govenor assembly but didn't know about the serial number
Joe Young
02-24-2014 16:10:05
 Re: Case 530 in reply to Luke higgason, 02-24-2014 13:42:09
No, just couple pictures of the sides showing engine compartment and front end. A picture of the dash and one from the rear.
