Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
2670 transmission pressure gauge
1968 403
02-23-2014 18:38:15
Hi everyone. The indicator on the tranny pressure gauge runs in the lower part of the green it has since we bought the tractor. Tractor shifts and pulls fine. We use hy-tran and Case filters. Could the low pressure reading be a sign of possible powershift trouble to come? TIA Keith
Henrik Jansson
02-24-2014 09:12:55
 Re: 2670 transmission pressure gauge in reply to 1968 403, 02-23-2014 18:38:15
I have two Case 1370, and thats almost the same transmission. The pressure gauge is maybe not that accuracy. If you want to know for sure, I think you should connect a external more accuracy pressure gauge. My two tractors does not show the exaxtly same pressure, but I think that depands on the accuracy in the pressure gauge. But if it shows different pressures depending on the gear, I guess something is wrong.
1968 403
02-24-2014 15:41:57
 Re: 2670 transmission pressure gauge in reply to Henrik Jansson, 02-24-2014 09:12:55
I have wondered how accurate the pressure gague is Henrik.
02-23-2014 20:25:41
I have had my 2470 for 20+ years and it has always run on the bottom of the green also. Shifts and pulls good. I shift to the speed I want and then put the implement in the ground, thinking it saves on the power shift. I have been told the hyd. pumps are discontinued.
1968 403
02-24-2014 05:52:32
 Re: 2670 transmission pressure gauge in reply to casecollectorsc, 02-23-2014 20:25:41
casecollector we have had the hydraulic pump rebuilt on our 2590. Theres 2 places around here that rebuils them. I was somewhat concerned about the low transmission pressure reading. Thanks for the reply
