Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 990 Injector Pump Leak
Al BAker (pumpman)
02-04-2014 08:36:03
Leaks are common on a CAV DPA pump that has seen some age. They are what I call a bomb proof pump that seldom has much trouble,just leaks once in a while. Pull it off and have a shop reseal it. If the pump is leaking on the outside it may start leaking past the drive seal and put diesel in your oil pan. Call around and check on prices. Some shops will hit you hard. I would suggest taking it to someone who can run it on a test stand when done to check it over correctly. buying a kit on ebay isnt allways the best answer. Sometimes a warranty is worth a few extra busks. I usally get $450.00 to reseal the pump and go through the nozzles. Good luck. 231/757/0064
Highland
02-04-2014 11:25:42
 Re: 990 Injector Pump Leak in reply to Al BAker (pumpman), 02-04-2014 08:36:03
Thanks I will do that. I'm a fairly good mechanic but I've never had an Injector pump apart. Wish that I could see where this drip is coming from. I know that it's originating on the back side of the pump but I can't see where.
Speaking of fuel in the crankcase oil pan. I get crankcase oil into the power steering reservoir, especially when the weather is cold. I mean it will fill up the reservoir and overflow. The shaft seal on the power steering pump must be bad and somehow letting the pump suck oil out of the crankcase. I probably should start another thread on this.
RGMartin
02-04-2014 12:49:02
 Re: 990 Injector Pump Leak in reply to Highland, 02-04-2014 11:25:42
The seal on the PS pump goes bad and draws engine oil through the seal rather than oil from the reservoir. Change the filter while you are at it, a plugged PS filter seems to make it worse.
I have seen it many times. It is utterly confusing the first time you see it as it doesn't make any sense at all. Case sells the seal kits for $30, they are available aftermarket for $10 or less.
