Sure am getting the Shaft this winter.
1370rod
Yep, this is the third time I will have to get a PTO shaft this winter. Also on this 2594 I noticed a new option I have never seen before. A visegrip used to remotely engage the PTO from ground level. This tractor is only used to spread poo, I have no idea why you would engage the pto standing on the ground rather than being in the cab. Rod.
Is the pto cable broken? A pair of vise grips lived on the valve of our 970 for many years. Back in the day dad thought Case's cable prices were too high, they sure haven't got any better.
ditto .. the 51 DC or the 800 always pumped manure with me .. rod ,, you are makin repairs for different folx in your area ?? rite ?,,. if same perpetrator I would look for common denominator,,,neighbor had a haytub grinder that liked to gut pto clutches ,, took out a big ac ,
on our poo pump tractors we try to get a throttle out side on them too. when you have one person at the barns with 3 pump tractors stirring and filling semis you don't have time to climb up in the cabs then some of the older tractors we have the cabs are not to user friendly.800,000 - 1,000,000 gallons a day little things make a big difference
