Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 630 Hitch Capacity
Adirondack case guy
02-03-2014 15:30:05
What do you want to lift and carry. Lifting #'s at the arms is fare diff., than say a 4B MTA plow, which a 630 will handle well; with 500# of nose weights.
02-03-2014 17:07:05
 Re: Case 630 Hitch Capacity in reply to Adirondack case guy, 02-03-2014 15:30:05
Yes, I understand what you mean. I would like to see all 3Pt equipment specify a minimum lift capacity requirement. 2000 lbs at the end of the lift arms and 2000 lbs 4 feet behind the lift arms are two different things. Various tractors I have found lift capacities for, some are surprisingly high, some surprisingly low. I have an old 26 HP, 2350 lb Kubota with a specified lift capacity of 2650 lbs at the end of the lower links.
I have a 7' cultipacker with a straw stitcher. Probably about 1200 lbs.
It would be nice to know what the 630 capacity is.
John Saeli
02-04-2014 12:55:54
 Re: Case 630 Hitch Capacity in reply to K-Mo, 02-03-2014 17:07:05
When she was new, a 630 would snap a set of 3-16"s up in a heartbeat. 50 years later, & a worn pump, she may not even lift them. The pump condition will be the limiting factor.
