Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
ignition on 430
brian stanek
01-21-2014 15:58:38
207.102.37.141
working on my 430 case. it usually starts quite good but does not like it much if over choked. points were burnt so new points and condenser plus a new dist cap. now it runs worse than before if it starts does not run on all cyls. i also changed the rotor previous to this. such a simple system but it is really confussing me. compression tested very good. what am i doing wrong?
[Reply]   [No Email]
VAC400
01-22-2014 11:11:59
64.246.113.88
 Re: ignition on 430 in reply to brian stanek, 01-21-2014 15:58:38
Brian, I am not sure if your rotor has a clip in the space [knoch ] that goes over the distributor shaft. If it is missing it will cause engine to run bad, should be tight. Check your rotation of the distributor an make sure your wires are correct. I have also seen a bad coil and new parts cause this problem. Jerry
[Reply]  [No Email]
brian stanek
01-21-2014 17:37:15
207.102.37.82
i set points to .020 as it says on engine. sure i got cap on rite. my manual is not very good. when i got the tractor someone had put an alternator in it. it is on 12 volts neg ground is that correct? also can i use a lit to time it?
[Reply]  [No Email]
Adirondack case guy
01-21-2014 17:10:38
74.69.160.79
Make sure the metal cap over the points is properly clocked and seated, in the distributor housing, and the distributor cap is setting properly on top of the metal cap.
Loren.
[Reply]  [No Email]
MDMO
01-21-2014 16:39:21
67.221.205.76
check the last thing you fixed if it is worse Point gap may be incorrect or wires not in cap good or incorrect places and new parts are not always better.
[Reply]  [No Email]
casecollectorsc
01-21-2014 16:34:59
64.33.230.59
Did you set the gap correctly on the points? Guessing they should be gapped about .020.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
