big 400 power steering bracket
I finally got a power steering pump off ebay. I think im missing some of the bracketry. P.s. pump came off of a 930. Trying to put it on the left side of a 400 diesel with an alternator conversion. Anyone have a picture of what this bracket setup is supposed to look like? I may end up just fabbing something but would like a picture to figure out what I'm missing.
One of my 400s is in my shop with all the tin off. I'll snap a pic this pm and scan it etc after dark today if no one else responds. Cattle to feed and check water for, out on pasture and it's still -18 @ 10am.
oldproudvet
I'm another that would like to see that picture. Cannot keep the belt tight enough to keep ps from squealing. Thanks, Brian
(quoted from post at 08:35:55 12/07/13) I finally got a power steering pump off ebay. I think im missing some of the bracketry. P.s. pump came off of a 930. Trying to put it on the left side of a 400 diesel with an alternator conversion. Anyone have a picture of what this bracket setup is supposed to look like? I may end up just fabbing something but would like a picture to figure out what I'm missing.
You can use it but you will have to move the return hose barb on the resivoir because it will hit the fan shroud. I have a 400 and 800 in my shop if you want to stop by and look for yourself give me a jingle I'll be in the shop all weekend twosixtwo2tensix4three1
When you get to the alternator conversion ,keep in mind that you will have to shim out the alternator to get proper pulley alignment. Do that first. Pulley alignment is critical. #010747AB is the generator strap{bracket}.I took the original strap and traced out with construction paper to the shape I needed. To get the correct belt, just tell your NAPA man the diameter of the belt. Borrow you significant others sewing tape{ask permission first]. It works well in getting proper belt diameter. Good luck
(quoted from post at 19:55:04 12/07/13)
I'm going to be near Burlington today. I'll give you a call. Maybe I can stop by and check out your setup. Thanks!
Nick
