TractorLinks.com
Show Parts for Model:
Dumb Question
Don Rudolph
12-06-2013 10:12:52
I purchased a new battery charger last summer and failed to get one with a 6 volt option. Is it possible to charge a 6 volt battery w/a 12 volt charger, or will it ruin the battery, or the tractor's electrical system? Thanks, Don
dzc3
12-09-2013 17:57:36
 Re: Dumb Question in reply to Don Rudolph, 12-06-2013 10:12:52
Keep it simple Jerry W has nailed it!
Adirondack case guy
12-06-2013 16:51:05
Don,
Tried e-mailing you but it wouldn't go through. It was in reply to your new shop. My e-mail is open, try giving me a shout.
Loren.
soundguy
12-06-2013 14:32:37
yes and no and maybee no.
if it is a 'smart' charger.. good luck.
if a plane jane xformer and diode job.. then technically.. yes. if you use a kludge series load you CAN charge up a 6v bat.. that's the non tech version. there are a few hurdles for hte technical moinded about laod change as the bat charges.. etc...e tc.
Jerry W
12-06-2013 14:10:02
Hook your 6v battery in series with another 6v and then charge it.... or put your 12 v charger on its lowest setting and then understand that you are putting a 'boost' charge into you battery and do it for just a short time.
Jerry
Johjn Saeli
12-06-2013 13:50:45
I wonder if you could use a resistor? My '54 Dodge has 2 Group 4 6V's in parallel, & I have put the 12V charger in the "Low" setting on them for a short while, w/ no problems.
RJKeith
12-06-2013 16:34:08
 Re: Dumb Question in reply to Johjn Saeli, 12-06-2013 13:50:45
No. You must match the internal resistance of the battery, which changes depending on the batteries charge.
nebken
12-06-2013 13:28:02
jump starting 6v on 12 is very hard on the regulator.
Case Nutty 1660
12-06-2013 10:25:37
I have never found a way to do it Don, I have found a great charger for the 6 volts are sold at Home Depot its a Black & Decker unit that slow charges/maintains and will do 6 and 12 volt cost is 20.00 here
j hikemper
12-06-2013 13:12:18
 Re: Dumb Question in reply to Case Nutty 1660, 12-06-2013 10:25:37
agreed .6 and 8 volts need a 6 volt settin. while we are on that question,,, I have jump started 6 volt with a 12 volt system ,,i always turn off the 12 volt engine ,,, because, i fear there mite be a gremlin in the worx ,, so far so good..
