C2 retard check ball and spring
Eddie7295
When we removed the transmission contol valve the check ball and spring was sitting on the gasket not in the valve body? I called case the part # A62641 a star keeper that holds the sring and ball in the valve is no longer serviced from case, has anyone had any luck useing something else to hold the spring and ball in the valve or can you get one used?
Not sure what model you are working on. On-line parts book for 1370 shows part number A58439. Hope this helps.
Eddie I have seen this before an was able to rob one from another valve I guess you don't have this option,maybe a automatic trans shop if you can determine size.
If you have the locking star, in tact, carefully restake it into the valve body with a small screwdriver. It wasn't uncommom to see them as you described during disassembly.
Loren
It is an 870 dont have the star keeper the spring and ball was all that was sitting on the gasket dont know if it was put together that way before we got it or the keeper is in the belly of the the tractor rebuilding the rps 34 and want everything back the way it should be. Thanks for all the input!
I had the same thing happen when I rebuilt my 1370.
The star keeper, ball and spring all came as an assembly from case that was 4yrs ago.
(quoted from post at 10:32:50 11/10/13) I had the same thing happen when I rebuilt my 1370.
The PN A58439 is still a good number, available from Case, Beside that we have 10 in stock at the dealership here in Pa. $1.88 ea. Just checked today for this post, Case supplies them as quantity 10 when ordered.
mEl
