Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Never seen one bury up like this at a Tractor Pull
Christopher Mikesell
11-10-2013 17:12:08
They also have cement dead weight pulls at Oakley. I have to agree with you there, it looks like it is terrible on the tractors.
If someone out there has never seen a competitive cement surface dead weight pull; Picture the following. A tractor is chained to the sled and the engine is revved up to an over speed condition. The driver then drops the clutch and the front of the tractor rises to a 45 degree angle off the ground. The driver then works the differential brakes and clutch in an effort to get the rear tires to alternately leave the ground in a right-and-left fashion. Once this has been achieved, the driver then uses the brakes and clutch to get both tires to bounce, slip, and grip simultaneously. This transition from right-to-left to simultaneous slipping is the tough part, and it may take several tries for the driver to be successful.
The front end of the tractor then works like a pull hammer as it swings up and down through a 20 degree range as the driver keeps the tractor bouncing with the clutch. This action then scoots the sled down the track. Obviously, these tractors MUST have wheelie bars.
Copyright © 1997-2015 Yesterday's Tractor Co.
