Mike in MI
I"m working on my brothers Case 570 Tractor this is a general model.
The Clutch assembly was very noisey so we change the throw out bearing. Looking at old Throw out bearing it had worn a groove in the center of the face on the bearng where the pressure plate levers rub. Didn"t look at the clutch and dicided to botton the tractor back up.
Clutch assembly still has a noise. It sounds like something rubbing or like a bad or dry bearing when the clutch pedal pushed in.
I"m thinking the clutch plate rattling but not sure if thats what it is?
I want to split the tractor again a pull the clutch and pressure plate out but he doesn"t want to tear into it again. He only runs this tractor in winter months scrapping snow.
I was wondering if anyone might of had the same simptoms as his?
Thanks for your help. Mike
