I was at an auction today and bought a plow just like the one in
the link below. Can anyone tell me what model it is? Are
replacement parts readily available? Thanks.
Case Plow
The pictured plow is a model BER 24 plow with slat bottoms. Depending on what bottoms you have, some parts are available NOS and/or after-market. Used parts are available too if you ask around. The main reason that you can still get parts is that Case continued to use the same wear parts on later series plows.
The BE/BER model plows were used on the SC and DC tractors with eagle hitch as well as the 200, 300, and big 400 series tractors (also with eagle hitch).
Due to the turnbuckle on the mast, the BE and BER-series plows can be adjusted to work well with both three point hitch and the eagle hitch.
The hardest parts to find are the furrow wheel and correct coulters. However, you can make a skid to replace the furrow wheel if you get the geometry right, and you can adapt other coulters.
There was also a plow with a roller at the back end of the mast which was meant for VAC tractors. These VAC plows look similar, but I don't think that they share many structural parts.
Thanks for the info. The tail wheel is pretty well shot, and it came with only one coulter, which itself isn't bad, atleast looking wise, but the bearings are worn out. Mine has been adapted from the Eagle Hitch mounting to 3pt mounting.
The bearings on the original coulters are adjustable by tightening the pivot bolt, and the disks are replaceable. Also, a good fabricator can replace the sheet metal on the furrow wheel if the hub and axle are both good. The bearings for the furrow wheel are also still available.
