930 head gasket question
cjackman
So before I tear down my 930 I bought an actual CASE service manual, and I ve been studying it. My question is on the head installation section, it says to check sleeve protrusion for the fire ring type. It doesn't say anything about checking it for the standard type. Why is that.
Case offered thicker fire rings to compensate for lack of sleeve protrusion which is now accomplished by shims between sleeve flange and block counter bore.An early parts book will give the part # of the different thickness fire rings. .003/.005 thousands is desired protrusion.
