VAC-14 Exhaust Manifold
Anonymous-0
Are all VAC exhaust manifolds the same? Mine is cracked. Are new/reproduction ones available? Are good used ones available?
Glenn F.
There is both an earlier and later style manifold and corresponding elbows. Your VAC-14 would have come with the later style. Both should fit the engine, but the air cleaner tube might not fit correctly with the earlier style manifold (assuming full height air cleaner tube). If you have the under-muffler system, then you might also have trouble with alignment.
On the earlier style manifold, the top center stud is longer and passes through the manifold. The same stud does not pass through the manifold on the later style; you work around the manifold to tighten it.
