TractorLinks.com
Show Parts for Model:
Re: Case 1290 won't start after fuel filter replacement
dubv
10-28-2013 17:08:34
I've pumped the hand pump quite a bit. I'm not sure how I'd fill the filters with fuel prior to putting them on...seems like it would leak right out the bottom until the seal was tightened by screwing them on....but I can attempt that tomorrow afternoon I guess.
Adirondack case guy
10-28-2013 17:25:44
 Re: Case 1290 won't start after fuel filter replacement in reply to dubv, 10-28-2013 17:08:34
Once you tighten the CAV filters down, remove the bleeder screw at the top of each canister and use a squirt can with fuel to fill them. Crack the bleeder screw on the injection pump and use the hand pump to remove the remaining air between the filters and pump. You may also have to crack a couple of injection lines at the injectors.
Loren
wvcasedbman
10-28-2013 17:20:32
There are 2 bleeder screws on top of filter housing open the one closest to seat and pump primer till you get fuel then repeat on second bleeder twards radiator should start. Afyer that if not repeat process be patient it takes alot of pumping also if tank is full helps alot gravity will speed up the prosses some
dubv
10-28-2013 17:37:16
 Re: Case 1290 won't start after fuel filter replacement in reply to wvcasedbman, 10-28-2013 17:20:32
Thank you guys...I'll take a crack at this tomorrow. Huge help! I knew there had to be a process, just hadn't done it before.
