Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: How to torque head bolts G148B (480B)
RC Brooks
10-28-2013 13:19:15
Just as a piece of information to add here, I did discover that if while using a crows foot, you keep the wrench at a 90 degree angle to the crows foot you will not need to compensate. I should have realized that, but still... I may try to fab one up. It"ll be a few days before the new gasket comes in anyhow.
Joe (Wa)
10-28-2013 18:07:43
 Re: How to torque head bolts G148B (480B) in reply to RC Brooks, 10-28-2013 13:19:15
RC, that is not true. The distance from the center of the crowsfoot square drive to the center of the fastener is lateral leverage and must be compensated with an equal distance offset at the center of the drive on the torque wrench.
On a vertical fastener the center of the torque wrench drive must be perfectly perpendicular to the center of the fastener for accurate torque.
If you want to use the crowsfoot w/o an equal offset you need to calculate the leverage. There are several sites that have basic calculations for that, do a goggle search.
10-28-2013 20:03:15
 Re: How to torque head bolts G148B (480B) in reply to Joe (Wa), 10-28-2013 18:07:43
Yes, now maybe I read wrong, but what many of those sites said was that by turning it 90 degrees (making an L out of the crows foot), you are keeping "L" (Lever Arm) the same for purposes of torque calculation. So rather than adding "x" number of inches to the lever arm, by turning it 90 degrees, you're adding 0 inches to the centerline of the lever arm.
But, I could be misreading/misunderstanding and quite possible that the sites could be mistaken.
Joe (Wa)
10-28-2013 22:13:23
 Re: How to torque head bolts G148B (480B) in reply to RC BROOKS, 10-28-2013 20:03:15
Ok RC, I am going to have to eat some crow on having the crowfoot at 90 degs.
Here is a site that proves you are right by using the calculator.
I am old but I can still learn if you beat on my head hard enough.
RC Brooks
10-29-2013 05:45:19
 Re: How to torque head bolts G148B (480B) in reply to Joe (Wa), 10-28-2013 22:13:23
OK, well I value experience more than I do websites. The physics of it I understand, but there are always things I may leave out, so I appreciate corrections as needed.
