Got a different job this afternoon.
1370rod
I know the message should read something like Done With Corn, but this is all the ears I could find laying around. Its now time to till the soybean stubble so the 1370 is put to work. It just plays with this 20 ft IH 480 disc. I go in 3rd, 2 ps at 15 to 1600 rpm's. Any faster and the disc throws dirt to far and I end up ridging the ground. At this speed everything stays level and works good. Rod.
I never get tired of seeing your 1370. It is a very sharp tractor. I started chopping stalks with the 2590 yesterday
Hmmmm! I think you've been holding out on us.Do you have two 1370's? The one pulling wagons looked to have axle mount duals and a mirror. The picture of the 13 and disc is awesome.
Rod, the air intake update that put the air intake on top of the hood, was suppose to add some power to the tractor,did you put this kit on,or was it on there when you got the tractor.
She is one sharp "1370".
Loved your point too! "CORN IS DONE"
Dan we installed dozens of those prescreen kits. The purpose was to eliminated the constant plugging of the air induction system with small pieces of corn leaves which made there way past the hood panels and into the radiator area. Even on 24+2670's we retrofitted the screen on those tractors because of the same problem. The problem was corrected on the 23+2590's with the air intake on top of the hood. Rod
