Mark Stintzi
New User
I just replaced my draft control valve and got rid of most but not all of my problems. Now, and intermittently before, when you use the control lever for the 3 point and raise the implement the transmission pressure gauge goes to red, on the right of the green. When you stop raising, the gauge goes back to green then further to the left to the yellow then eventually back to the green. And when you use the remote pair of valves, without any cylinder so just the pressure relief valve is working, the gauge goes to the red to the right of the green, then when you stop it just goes back to the green. Performance wise the pump seems to work well so is it a valve somewhere again? Only parts left are the flow divider and the remote valve. Any suggestions? Thanks. Mark
