Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1070 power shift four speed problems?
1370rod
10-14-2013 17:15:15
If everything is moving properly on the outside you know it trouble is inside. Remove the square plate from platform floor. Wash the top of trans thoroughly and remove the small tin cover that the nuetral switch threads into. Now by shifting the linkage you might be able to see the problem. If that all seems OK then the trans top cover needs to be removed. It might need to be removed to repair the problem anyway. Deal with that after you locate problem, Rod.
Fred E.
10-14-2013 20:09:44
 Re: 1070 power shift four speed problems? in reply to 1370rod, 10-14-2013 17:15:15
Rod, I appreciate the input. That is were I will look and see.
Thanks,
FE
