Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: test driving a 70 series, checklist?
4435
10-14-2013 09:09:11
8 speed or power shift? The 8 just listen for bad sounds nasty leaks be nice if you can sneak an oil sample or two. Ask for a hydraulic flow test and a dyno. A dealer should be happy to do that if it makes the sale. It will grind into gear if you don't hold the pedal down for several seconds. And then may butt tooth.
Power shift, all the above plus the grunt when you push the clutch in. Shouldn't grind gears, crisp shifts try to stop the tractor in each PS shift point with brakes. Should be kinda whiny in reverse. The planets are screaming there. Tom
P.S. I am sure I missed several things.
This post was edited by 4435 at 09:10:35 10/14/13.
pistons
10-14-2013 09:18:30
 Re: test driving a 70 series, checklist? in reply to 4435, 10-14-2013 09:09:11
Great, did not know the dealer would dyno and do a flow test for free. Will ask them.
It is an open station Powershift.
