TractorLinks.com
Show Parts for Model:
Re: Hey 1370rod
1370rod
10-13-2013 19:30:34
I never have had any plates surfaced. I do not know of any spec's as to how much material can be safely removed. Without seeing them it is hard to make a comment on what to do. A lot of plates do show some wear, but it is relatively flat and does not cause problems. If the plate is not grooved or deeply scored personally I would reuse it. Replace the clutch disc's and you should be good to go. If your powershift is apart reseal the pistons. If your pistons have the exspander wire behind the seal toss them and get new style pistons that use a o'ring under the square seal ring. Rod.
Eddiein Ky
10-13-2013 19:54:57
 Re: Hey 1370rod in reply to 1370rod, 10-13-2013 19:30:34
Thanks on the sun gear the one i have has six rivets that hold the disc on . The disc from the 1370 a142536 would that be the one to replace the disc on the sun gear?
1370rod
10-13-2013 20:05:16
 Re: Hey 1370rod in reply to Eddiein Ky, 10-13-2013 19:54:57
Good that the sungear has the rivets, much easier to replace the disc. If thats the no. for the C-1 disc, then its the one you want. I don't have a parts book handy to check the no. That disc will come with the 6 holes to install the rivets in. Rod.
Agri King
10-14-2013 04:49:19
 Re: Hey 1370rod in reply to 1370rod, 10-13-2013 20:05:16
Rod, My machine shop buddy programmed one of his machines to cut the splines for the old style plate. If you are in need of that being done.
1370rod
10-14-2013 06:26:05
 Re: Hey 1370rod in reply to Agri King, 10-14-2013 04:49:19
Hi Eric, thats good to know. Rod.
