Michael Andros
New User
I recently purchased a Case 631C-H. In checking fluid levels today before doing some grading I found the trans level to be unacceptably low. As I have not yet received the maintenance manual for this tractor I am at a loss where the fill tube is for the trans other than using the trans dip stick tube which while it may work is exceptionally small.
Also other than seeing Dextron being used is there a factory recommended trans fluid. I believe it is classified the Case-o-matic as it has 4 forward/1 reverse in a low/high combination.
Thanks for your help!!!
Mike
Mike
