Injector gasket/seal to head on a 400
oldproudvet
Do one of you guys have a part number for the copper seal that goes between the injector and the cyl head on a Racine 400? I've spent the last hour in my parts book with zero success. I pulled the injectors and pressure/pattern tested them on my neat little Bosch device, to discover I had a pint of water in the fuel tank.........Oh well it was just a day of screwing around. Thanks
The gaskets can be annealed and reused. Hang them on a wire and heat to a dull red with a torch and immediately dunk them in cold water. They will be softened and will reseal.
Gene
