TractorLinks.com
Show Parts for Model:
Case 1948 DV Serial # 5218256 Restoration
David Graham
09-18-2013 08:38:39
This is my first Case restoration. This tractor uses shutters to control the engine temp. but the upper block to tank elbow appears that it can accommodate a thermostat. A thermostat doesn't appear in the parts book. Is it possible to install a Thermostat.
Also I am not sure if I should paint the shutters Flambeau Red or Cast Gray. Thanks Dave
Ferdie
09-26-2013 18:23:32
 Re: Case 1948 DV Serial # 5218256 Restoration in reply to David Graham, 09-18-2013 08:38:39
David,
Hi again! I got a look at the Late D model Parts book and the Thermostat is PN 08989AB. It appears to fit in the tank end of the tank outlet elbow.
I sure would appreciate those pics of the fenders too. Thank you.
Regards, Fred
Ferdie
09-18-2013 16:05:04
David,
Hi. I believe the later model DV parts book shows a thermostat, I will check this weekend. On another subject, does your DV happen to have the vineyard fenders? I have a '51 DV, and am looking for vineyard fenders to take pictures of and get measurements for.
Thank you, Fred
David Graham
09-18-2013 22:35:28
 Re: Case 1948 DV Serial # 5218256 Restoration in reply to Ferdie, 09-18-2013 16:05:04
Hi: Yes my DV does have the vineyard fenders. I will have to take some pictures for you. Dave
s,mac
09-18-2013 20:08:18
Hello Fred let me know what info you need for your DV i have a 1941. Steve
1031D
09-18-2013 08:45:02
Everything is Flambeau except for the rims, starter, and generator. As for the shutters and thermostat, the shutters were either to help a kerosene engine warm up faster or as a cold weather aid on a gasoline tractor. Thermostats were an option.
