Case 1194 drawbar
Anonymous-0
Hello all I recently picked up an 1194 for next to nothing!! The best part is that it runs great too! Anyway I am in need of a drawbar for this tractor. The part number is k946154. I found one on eBay, but there is a local tractor salvage yard I know of and was wondering what other tractors had the same drawbar. Also, would any of you know the dimensions of the drawbar?? Thanks!!
Also, since my land is very very flat, and all I'm really doing is skidding logs and pulling a firewood trailer, would it be more cost effective to get/build a 3pt drawbar? One that attaches to the toplink?? What are your opinions??
I have a Case built 3pt drawbar that uses the top link. It has been on my 300RN since I got it 8 years ago. It is handier than a set of jumper cables at a redneck wedding. I have several wood trailers, and other trailers that I used when I was in the contracting business, and when I need to move them around, I just back to the toung even if it is on the ground and drop the pin, and with the ball hitches, it's a matter of hand tightening a ball on the hitch and backing under the toung, raising it up and moving it and then dropping it. Never have to get off the seat.
for skidding logs you will love the way the 3pt drawbar raises the butt of the log, and as you pull forward the toplink actually applies downforce to the front of the tractor. You just can't use the pto with it.
Loren
Any of the mid sized DB drawbars should be fine in it, 885, 990 or similar. Any yard worth their salt should have several 990s.
As to skidding logs, a properly built 3 point one would be the ticket.
So I found at least two sources for the original drawbar but I think I am leaning towards a three point one.
Either way by looking at the original drawbars, I see that there are 5 holes total. There is one for the implement hookup at one end, and two smaller holes near the implement hole to add on the clevis bracket. At the other end, there is the hole for the pin under the tractor, but then there is a 5th hole similar in size to the tractor pin hole diameter but it is more towards the center of the drawbar. I think it is just for drawbar length adjustment, mainly for using pull type pto implements, but i am not positive.....so What is this 5th mystery hole for?? I'm just
wondering and thanks for all the info!!
