TractorLinks.com
Show Parts for Model:
Re: 3rd gear 2670
1370rod
09-17-2013 05:42:00
Sounds like you are talking about 3 rd gear in the 4 speed trans. The only reason I can think of is slippage in the power shift or torque limiters. But then you should be able to get it to slip by loading the tractor in the other gears also. Rod.
Jerry he
09-18-2013 05:00:19
 Re: 3rd gear 2670 in reply to 1370rod, 09-17-2013 05:42:00
Yes the problem is in the 4 speed box. It will move in third until it gets a small load on it. It makes a whinning sound when it stops, does not do this in any other gear. Could it be possible the gears are not meshing together when shifted and it is only getting a friction drive from the gears just rubbing on each other? Does working on this require an engine and power shift removal? Thanks.
