Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: hydraulic problems on david brown 990
RGMartin
09-17-2013 04:31:11
Buried in projects up to my chin(Corn needs to come off soon, wheat needs to go in, lots of old worn out equipment needs TLC to do the job). Not as much internet time.
See if I follow what you are saying, if you raise the 3 point arms, they go all the way up, no matter what you do to the lever(including blowing the relief valve)? If you shut the tractor down with them in the up position, do the arms respond properly to the lever on the way down?
If the above is true, it sounds like a stuck "Latching Valve" in the Selectamatic valve body. It is a low dollar fix(some gasket material and 1500 grit paper), but will take at least 3-4 hours to pull the valve to fix the problem.
