Crazy Horse
Looking at a Case 812B that has a loader on it. Some previous owner removed the rear factory pump, kept the hydraulic tank and rear mounted a PTO-driven aftermarket pump which is used to power the front end loader. Loader is a bit slow the way it sits now, maybe 540 RPM's isn't quite fast enough?
Since I would like to be able to use the PTO for other uses, do you think a factory pump would have the power for loader work? I have a parts tractor with the factory pump on it but am wondering if the swap back to using it would work for the loader.
