Dan Davidson
Yesterday I was square baling with the 930 in 1 high. All was going well. I stopped to pick up a bale lying in the field. I put the high/low in neutral. When I got back on the tractor a minute later it would just grind when I try to put it in high. It's not in the linkage. Goes into low just fine. When I put the transmission in neutral it kinda goes in part way but when I let the clutch out it grinds and pops out of high right away. I'm thinking the high speed gear must be spinning on the power shaft when the shift collar is in neutral. I know these high low gears can weld to the shaft. All too well. I only have about 20 hours on this machine since I was in that transmission. Any ideas??
