David Brown 990
UP Oliver
I posted this request on the tractor talk spot, thought I would try here to.
I need a new injector line for my DB 990. Anyone know where I can get one?
Thanks.
I just googled david brown parts and came up with a place.... www.davidbrownparts.com I dont know if they will have what you need but it is a place to start...
Which line? If the return line that goes across the top of the injectors(most often damaged one), it can be fixed with 3/16" compression fittings. I don't know of an aftermarket source for them.
It is the line that is closest to the tractor, going from the injection pump to the 2nd injector from the front of the tractor.
The throttle line rubs on it and put a hole in the injector line.
Thanks.
