Last time I went plowing in the fall around 40 degrees .. my La started to run HOT .. so after a 1/4 mile of plowing ... I had to pull off to the side and let it cool down { left it run }
YES the lovers were WIDE OPEN .. so I just was thinking may-be rust and stuff got the bottom neck partially plug ..
took the neck off today and stuck a hose in top , not much but a little color water came out .. flush for 10 min. or longer
WHAT would you think ,my problem could be ... hoping to do some plowing again this year ..
fan belt is new and tight { move it 1/2 inch , but not more than 1 inch ..
Thinking it might be the water pump .. can they be rebuilt ... or do I need to start looking for a new one ..
THANKS for any and all the information you will share with me ..
.............. mark
