TractorLinks.com
Show Parts for Model:
Re: 830 Case clutch
mEl
09-15-2013 06:19:49
I would split it and have the flywheel "step distance" measured and brought back to new spec. If the flywheel is worn badly the pressure plate has to extend further to reach the disc causing the fingers to extend further.
I was not aware of the different thicknesses of the driving discs and have used either without any changes to finger dimension. Clutch shaft wear could be an issues as stated so should be eliminated as a cause while apart.
I would look at the flywheel before condemning anything else.
mEl
This post was edited by mEl at 06:20:27 09/15/13.
dwag
09-15-2013 07:01:59
 Re: 830 Case clutch in reply to mEl, 09-15-2013 06:19:49
Agree, checking flywheel step spec is crucial plus finger height in a clutch job, but poster stated clutch worked fine for four months? regards john.
mEl
09-15-2013 13:14:28
 Re: 830 Case clutch in reply to dwag, 09-15-2013 07:01:59
dawg,
good point, sounds like one of those things that we'll just have to see when it is split, something loose and floating around is a definate possibility.
mEl
