Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Case MX100C Injector pump timing
Dieseltech
09-08-2013 08:49:27
Yes, the lock timing bolt is at the drive end of housing, has a shoulder for the large hole in plate to slide over so end of bolt can thread in farther to lock the shaft in place. The drive hub must never be removed from pump, only the gear so hub can stay with the pump. Hub is properly located after pump is tested per the test plan spec.
Timothy B
09-08-2013 13:38:31
 Re: Case MX100C Injector pump timing in reply to Dieseltech, 09-08-2013 08:49:27
I've got to take it to the Diesel shop to get the pump resealed - looks like they can jump up and down about me removing the hub!
Thanks for the info.
Tim.
