here is the pic... I had trouble uploading it last night
from what I see she looks good, the tire issue,,, are both rears a matched set and are the fronts as well? check tow in set as per book also raise front wheels off the ground and see if you have any slack/movement in the spindle area
cnt
forgot to add the fronts and rears need to be pretty much the same wear as well to be running the same speed also make sure the FWD is kicking out as roading with it locked in will cause excessive wear also
