Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 580
karl h
09-08-2013 06:58:45
here is the pic... I had trouble uploading it last night
karl h
09-08-2013 06:59:35
 Re: 580 in reply to karl h, 09-08-2013 06:58:45
the right tire is wearing funny but everything in the front end seems ok...any ideas?
Case Nutty 1660
09-08-2013 07:08:18
 Re: 580 in reply to karl h, 09-08-2013 06:59:35
from what I see she looks good, the tire issue,,, are both rears a matched set and are the fronts as well? check tow in set as per book also raise front wheels off the ground and see if you have any slack/movement in the spindle area
cnt
karl h
09-08-2013 07:13:52
 Re: 580 in reply to Case Nutty 1660, 09-08-2013 07:08:18
rears are new firestones. the fronts are matched. I will check the tow thanks nutty!
Case Nutty 1660
09-08-2013 08:11:42
 Re: 580 in reply to karl h, 09-08-2013 07:13:52
forgot to add the fronts and rears need to be pretty much the same wear as well to be running the same speed also make sure the FWD is kicking out as roading with it locked in will cause excessive wear also
Copyright © 1997-2015 Yesterday's Tractor Co.
