VAC-14 Foot Throttle
How many bends is the foot throttle link supposed to have on the VAC-14? Mine was bent up and it looked like it originally had 2 (not counting the 90 deg. bend at the one end). However, I now suspect that it should have only one bend. The parts manual sketch is not clear enough to resolve this.
Checked 3 and they are all a little different but there was only 1 bend, probably about 8-10 degrees of bend and it is between the brake shaft boss and the back rib of the upper equipment mount. This one has a larger radius in the bend than the others. Lee
