Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 430 Brake Problem.
09-06-2013 19:30:39
I sacrifice a cheap 90 degree o ring pick and shorten the tip and slightly flatten it and insert it between the two shafts and under the seal lip and turn it 1/4 turn and use side cutters to grab the shaft of the pick and use the end of the shaft as a fulcrum point to lever it out. You should measure how deep the seal is in and make a driver out of exhaust tubing with a stainless steer hose clamp located as a stop to keep from driving it to deep. We dealers have a special tool to drive them but some applications will not allow it's use. I can see removing the main brake shaft seal with a sheet metal screw but never considered doing it with the diff lock shaft seal.
09-07-2013 00:56:42
 Re: Case 430 Brake Problem. in reply to mEl, 09-06-2013 19:30:39
I have LS430,when I start the car most times it's fine, but when I take off from Park to Drive the SKID command lightweight comes on and beeps and the vehicle begins to brake on it own..What is the reason behind it? Any proposals ? I am also going through Auto Repair Mission Viejo.
