Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Case 430 Brake Problem.
09-05-2013 20:46:13
I had the same problem on a 580 backhoe last winter. I drilled a tiny hole in the seal and pulled it out with a sheet metal screw. Worked GREAT!! Make sure your brake shaft bearings are tight. If not the seals will never hold. To tighten remove shims from the proper side to maintain ring gear and pinion clearance.
