CASE 1030 HYDRALICS
GAYLEN FIGY
New User
I have a case 1030 and the hydralic some times work good and then they work really slow and will barely lift the disk and will them work good again. Some one told me the SPOOL VALVES ARE STICKING. Or is it some other problem if it is the spool valves whats the fix?
First thing to check is the hydraulic quick couplers. Many times they do not fully unseat to allow fluid to pass. Try reversing the hoses and see if there is a change. Maybe try a different cylinder to see if the connectors work better.
Gene
Have you checked your hyd. oil?? Is it at all milky? Recent hyd. filter change? The 30 series has a habit of getting moisture in trans. is why I ask, you could have gummy,milky sludge in filter.
thr hyd pickup. tube stoped up once in my 1030 ,it got real slow in lifting ,the preasure checked ok but was real slow,you have to pull off the pto and hyd pump housing , good 2 hr job ,if u decide to check the screen ,pull out the top 2 bolts 1 on each side and install 8 or 10. inch bolts this will allow u to slide the unit back off everthing while keeping it strait ,hope this helps tom
