Question for casecollectorsc
NickatKY
casecollectorsc,
Can you post a picture of your friends freshly painted VAC with the remote valve?
Is it early or a late model VAC?
I have the factory parts to put a double acting remote valve with couplers on an early VAC. It is part of a kit Case offered to upgrade the early VAC's to live hydraulics with a remote cylinder mounted under the torque tube.
Thanks Nick
(quoted from post at 05:40:27 09/05/13) casecollectorsc,
Thanks Nick
Nick, I have the installation book for it on an early tractor. I also have a torque tube for an early tractor without Eagle Hitch that has the return line plate on the side for a double valve to mount.
(quoted from post at 14:09:54 09/05/13) I don't have a pic of his tractor or the valve. He lives about a 100 miles from here and isn't into computer but will see what I can do.
No Hurry, I would like to see sometime. Do you remember if it was an eagle hitch tractor?
Thanks Nick
Nick, I have the installation book for it on an early tractor. I also have a torque tube for an early tractor without Eagle Hitch that has the return line plate on the side for a double valve to mount.[/quote]
Jim
I will have to look at my books and parts and compare notes with you sometime.
Thanks Nick
